Anyone ever change the fuel filter on their 03 cavy?  I have hit 50,000 miles and would like to change mine myself.  Just wondered if anyone had any advice.
Dude its easy as 123 all u do is jack up the back end of your car and u will see it right  behind the rear axel all u need is a flathead screwdriver to undo the clamp and a wrench to undo the bolt the screws into the filter. But before u do this remove your fuel pump fuse and turn it over a couple of times this will release the pressure in the fuel system so when u take off your filter u dont get a gas shower. hope this helps
apparently its a lifetime part no need to replace it according to GM, correct me if i'm wrong
Jacob B wrote:apparently its a lifetime part no need to replace it according to GM, correct me if i'm wrong
what a bunch of crap that is........ive seen fuel filters with 20-30K on them with fuel filters completely restricted.......thats funny though, GM and lifetime filters......i wonder what pencil pusher said that
PhilioZ24 wrote:Jacob B wrote:apparently its a lifetime part no need to replace it according to GM, correct me if i'm wrong
agreed. if they had a lifetime filter, every manufacturor would be using the same thing. but think about it. its a filter. compare it to a pool filter, air filter, any filter you can think of. they FILTER things out, so if its filtering things out, then its going to have buildup regardless.
<A HREF="http://www.cardomain.com/id/eazy716"><IMG SRC="http://registry.gmenthusiast.com/images/eazy716/personal_pic.gif" BORDER="0"></A>
Stupid Q, but how much is it worth?? If it's dirt cheap I'll do mine this weekend. 03 Cav with 36,000miles
Thanks,
G
i think it only costs a few dollars, maybe as much as seven or eight, but its not expensive at all.  i did one a while ago i think around 30k.  ill do another around 50k before the bash.
Land Pirates sail the open roads
DISCLAIMER:  If anything I say offends you, I don't care..wear a helmet.  Also, the information
I post is what I know to the best of my knowledge.  If I am wrong, please correct me so that
others as well as myself may learn.
Premium sinc 6-17-04
Heres the proof from the GM service website
http://service.gm.com
Fuel Filter Replacement
Removal Procedure
Important: There is no service interval for fuel filter replacement. Only replace the fuel filter if the filter is restricted. Inspect the fuel tank internally and clean the fuel tank if you find a restricted fuel filter.
   1. Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure .
   2. Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
      Object Number: 408592 Size: SH
      Click here for detailed picture of above image.
   3. Disconnect the fuel filter fitting using a back-up wrench.
      Object Number: 54520 Size: SH
   4. Disconnect the quick connect fitting from the fuel filter. Refer to Quick Connect Fitting(s) Service (Plastic Collar) .
   5. Remove the fuel filter.
Installation Procedure
      Object Number: 288310 Size: SH
   1. Remove the protective caps from the new fuel filter.
   2. Install the fuel filter (2) in the same position as the old fuel filter.
   3. Connect the fuel filter quick connect fitting. Refer to Quick Connect Fitting(s) Service (Plastic Collar) .
      Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
   4. Connect the fuel filter fitting (3) using a back-up wrench.
      Tighten
      Tighten the fuel filter fitting to 27 N·m (20 lb ft).
   5. Lower the vehicle.
   6. Connect the negative battery cable.
   7. Inspect for fuel leaks using the following procedure:
         1. Turn ON the ignition, with the engine OFF for 2 seconds.
         2. Turn OFF the ignition for 10 seconds.
         3. Turn ON the ignition, with the engine OFF.
         4. Inspect for fuel leaks.
  	Document ID# 782399
2005 Chevrolet Cavalier
Important: There is no service interval for fuel filter replacement. Only replace the fuel filter if the filter is restricted. Inspect the fuel tank internally and clean the fuel tank if you find a restricted fuel filter.Procedurefff
The newer GM vehicles do not have an out of tank fuel filter, the only filter is the pump pickup sock.
Jacob B wrote:Heres the proof from the GM service website http://service.gm.com
post up where its at........to lazy to search through and find it.........
there may not have a service interval for it but that does not mean to ever change it
RE:::
Removal Procedure
Where on the site is this info contained?  Do I need to sign up for a password or something.  It almost looks like a site for technicians.
Just to make sure I am right, but it appears that the fuel tank as to be removed in order to access the fuel filter?  Someone mentioned having done this already.  How difficult was this procedure?
yes you need a password to get on there thats why i just posted the instructions and highlighted the part that GM says that the fuel filter does require changing. The comment about filter in the tank is not for the j-body thats for the newer GM cars. The fuel filter in cavs and sunfires is on the outside by the tank.
ok cool.  this site is so awesome.  don't know what i'd do without it.  prolly drive a honda
So how often should a fuel filter be replaced? My car is up to 100 000 kilometres and I never changed it.
I change mine once a year, just for good measure, and since its only an $11 part its not a big deal. I usually run a can of Sea foam with a full tank of gas before I change it out.
Because there is no listed interval doesn't mean you SHOULDN'T replace it... but to go more than 25-30k miles without changing a filter that cost less than $10 is foolish in my opinion.
Sig removed because some people cry too much.
</a>Scott Heflin, President Team Forward Motion  <a href="http://www.teamforwardmotion.com" target="_blank">TFM </a>
I always change my gas filter every year, regardless of how many miles usually at least 10,000 miles.  Once i changed the filter and 4 months later it was clogged.  First time that has happened to me.  It was on my 98 Z-71, it couldn't get it past 70mph and it got worse until i figured out what was wrong. Remember, u fill up with gas that is supposed to be filtered into your tank.  Then the  fuel pump itself also has a filter( not replaceable, then it goes through the fuel filter(replaceable), and into the injectors which sometimes have built in filters (not replaceable).  Remember gas is not always clean.  U need filters to clean the gas and replace the ones u can periodically.  Also ur gas tank collects crud inside and also the gasoline station tanks aren't always clean.  Also stick with one gas station that is reliable with ur car.
gas is NEVER clean have you seen the inside of a gas station tank? all that sediment and crap its crazy sure it may be "clean" when it leaves the factory, but when its dropped into stations its far from clean! hence why we have filters! cheaper gas you buy also plays a big role in the detergents in it and so on.. It's been said try to fill up at the same station using the same pump to cut down on alot of things and don't use cheap gas i.e. racetrac,wal-mart, BP(in texas), H.E.B., just to name a few.. all they do is buy up leftover gas from companies and mix it all together and sometimes its watered down to add $ (best buddy owns a few gas stations, and my roomie works for dresser wayne, largest pump maker in the nation) I my self used what ever gas I could lay my hands on, hell cheaper thebetter but now that I've learned I won't do that again!  plus I add my acetone into my gas also after each fill.. works wonders!
and good ol' seafoam into my intake to clean internals
beer is like a chick.. well not really its just beer, it be cool thou huh?
