well this has just started recently.. i just changed the fuel filter and i heard the fuel pump was replaced about 25k miles ago.. ive never done te sparkplugs maybe thats wuts wrogn anyway...  I start my car and go to drive its usually when i go into second or hit the gas in 1st i guess too but it just like bogs out n doesnt go it sputters thats the best i can describe it i have no check engine lines or anything It never dies or anything but it just like bogs out probably 5/10 times i drive it cold Never have any problems like this when its warm or anything.. any advice would be apperciated
anyoneee? i was thinking maybe the intake sensor ? for air flow
check you map sensor plug and vacum line.
<img src=http://domestictuners.com/banner.jpg WIDTH="400" HEIGHT="75" /img>
Hit 200 NA it broke once, Hit 213 it broke again,
Hitting 300 NA is further away than I thought.
wuts a map sensor and im pretty sure all my vacuum lines are good
map= "Manifold absolute pressure" sensor the vacum line comes off the bottom of this and goes to your intake manifold base. if you look @ the TB from the front it will be mounted to the right side of the TB and have 1 plug and 1 vacum line. Then line can crack or deteriate and began to leak, causes lots of pickup, idle, and hesitation issues.
well @!#$ i just put that thing back on .. not long ago it was disconnected for quite awhile and i posted and they told me where to put it ect.. but i dont remember any problems before i actually put it where it went just after i put it back could it of caused any major damege ect?
Dude, you need some grammar lessons ASAP!
Thanks,
G
GBro wrote:Dude, you need some grammar lessons ASAP!
u taling to me? wtf? how do  figure
Brandon Schmidt wrote:hahaah TALKING
Hahaha
Nothing offensive dude, you just make like a million typos per line in your posts that's it!
Thanks,
G
a million huh? id like u to show me a line where i made 2?
