Yea so i was checking all my fluids under the hood and other things like that, so decided to take the ecotec cover off to check the spark plugs, everything was fine i put the cover back on and the car won't start... can't figure it out, those tubes that go over the plugs all went in, it's just now i can't figure out why it won't start at all... no power, nothing. any ideas????
nevermind i got it, i'm a retart i forgot to tighten one of the bolts... is it normal to smell a little gas at first when that happens though, b/c when i started it, it started fine, but i got a slight smell of gas(door was open) from the exhaust, but it went away after about a minute.. any ideas??
5spd ecotec wrote:nevermind i got it, i'm a retart i forgot to tighten one of the bolts... is it normal to smell a little gas at first when that happens though, b/c when i started it, it started fine, but i got a slight smell of gas(door was open) from the exhaust, but it went away after about a minute.. any ideas??
You will smell gas for a minute, because the car is running richer until operating temp is hit. Once it reaches operating temp, and a few other coniditions are met, example car has been on for at least 60 seconds, O2 sensors are heated up,  it will enter closed loop operation.
hope it helps
thanks rob, appreciate it.
