i was just wondering if anyone can help me with the step of changing a fuel filter on a 99 cavi let me know thanx!
It is very easy. First jack up rear of car and remove the gas cap to remove pressure in the fuel system. Locate the fuel filter and remove the plastic clips at each end of the filter (a flathead screwdriver should do and don't worry about breaking the clips since new ones should be supplied with the filter). Keep a rag or container handy to catch any fuel in the filter. Place new fuel filter in the correct flow direction and reconnect hoses using the new clips. Now you should turn the key to just before the car starts to regain pressure and also check for leaks (do this a few times). That should be it.
Actually removing the gas cap wont release the pressure in the fuel system. go to your fuse box in the engine bay and remove the fuel pump fuse, then turn your engine over a couple of times and that will remove any left over gas in your system.
Sorry...that link didn't work right, must have hit the wrong button...try this
Fuel Filter Change
when you jack your car up you just unlug your fuel pump from underneath your car...the harness is right beside the fule filter...then turn the car over a few times and that  releases the pressure... this is how haynes manuals say to do it
Removing the stock fuel filter on a '99 Cav is a major pain in the ass.  You need the stupid plastic tool from AutoZone, etc. to get the clips off.  If it is not the stock one, you should be alright.
Email me if you have any more questions.
Rob
Sold 2/2/05
ROBZ IL CAV wrote:http://www.j-body.org/forums/read.php?f=11&i=78904&t=78873#78904
Also, here is the picture that is missing from that thread:
Rob
couldnt of put it better myself....ive tried to explain that but it was a waste of time........nice illustration
thats exactly how i do them at work when they come in that way
screw that.. lol  i took off a stock one and sure...it was a pain inthe ass but i didnt cut it at all..and thats not how they do it at the dealership either... all you have to do is get a small flat head screwdriver and jam it around in there for a little bit and the metal clip thats hidden in there will break right out...took me about 10 minutes
plus im scared to take a cutting tool to metal ( which will cause sparks) to my fuel lol
