i was going to go check my PCV valve on my car when i heard hissing and smelt gas....i looked around and there is fuel leaking around the wire conecter on the fourth cylinder (closet to master cylinder) i will try to get pics soon but how do i fix this? is it a gasket? hopfully ill have some replys when i get home from work at around 1 or 2 in the morning
thanks guys
probably just an o ring
14.82 @ 97 mph
and how do i go about putting on the new o rings
pull off your fuel rail and check the injectors for leaks or a pinched o-ring.
14.82 @ 97 mph
Make sure you take off the fpr or you will flood the cylinders and cause alot of problems.
I'll see if I can find the directions for you.
2.2 liter L4...and there a special tool to get the injectors on and off? or is there a special way???
thats the only illisration i could find that would help me
Just take off the bronze injector holder iner thingy. (sorry dunno the technical term)  Then I belive you just give the injector a twist and it comes right out.  I'll try to get you the full instructions soon.
all the injectors come out attached to the fuel rail, they're held on with little clips
14.82 @ 97 mph
the "the bronze injector holder iner thingy" is called the "injector retainer"...go to the earlyer posted link......but for now go to my cardomain pics page and see the damage on page 4 and tell me whats missing on my throtle cable line..i think it might be for my crusie control i dont have..(lol) huge thanks for all ur guys' help
AHhh now I see you have a 92 lol.   Where's the cardomain link?
and by fpr do u mean fuel presure regulator cause i took the top vaccum line off tht and then pulled the injector out and gas started to run all in the cylinders...once i noticed this i slamed in back in so i dont think i cause to many problems....be4 i started all the i took the fuel pump fuse out and turned the car over.....so i thought the lines would be clear...guess not......help!!!! loll
well key 2 gave me the wrong ones and lordco ordered the corect set from vancouver....so we will see....
