Alright I have no turn signals at all.  They are not flashing and I am getting nothing on the guages either.  I replaced all the bulbs and the fuses were good.  Any ideas?
Sorry might sound dumb for asking but I tried just about everything.  I was going to try a different gauge cluster but my turn signals work so I dont think it is that.  I also changed the switch to see if that might have been the problem but no luck there either.
I have not had the chance to replace the flasher but am going to try that next.  Just wondering if anyone else had this problem and how they fixed it.
i would try the flasher....thats what it sounds like
Any other ideas since I tried that and it wasnt the problem either??
Switch...?
-- The The One One --
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
Try applying power to the flasher relay (if possible) manually, could be a wiring problem somewhere.
Do your parking lights work??
On '93 Cavaliers there are TWO flasher units, one for the normal indicators and one for the Hazard flashers.
 I just wondered if this is still true for your car, make sure you have changed the correct flasher.
Alont
I am having this same problem. My signals don't work on my dash or on the actual lights, though everything else is working... I think I might have accidentally pulled something loose in the dash cuz it happened a little while after I installed my new head unit. Just trying to find time to get back in the dash..
alont wrote:On '93 Cavaliers there are TWO flasher units, one for the normal indicators and one for the Hazard flashers.
Alont
Yes the 1995 sunfires and cavaliers do have two flasher units and I replaced both of them.
We did check all the wires to make sure there was not a short some where and no luck.  We thought it was because of the side markers that are on the stock bumpers that i removed because of my rksport front but my bumpers have been on for a year and the problem just came about.  Any other ideas?
Thanks everyone for responding.
Proudly supports A+ Performance
Probably a bad multifunction switch (turn signal switch).
God bless America.
Hi Hotfire
So you have changed:-
1.  Multifunction        Turn/hazard switch
2. Flasher unit   (Both Turn and Hazard)
3. Checked Fuses   Turn b/u 20Amp and s/lp fuse 20 Amp
It can only be a wiring/earthing problem.
I did have a problem with my Daytime running lights   /   A/C not working.
These run off the 25Amp A/C fuse and although it tested good on a meter and looked good visually I had to polish the fuse contacts with fine wet and dry paper and then put the fuse back in before everything worked normally.
It just was not making a good contact before the cleaning, had sort of a film on the contacts.
 I just wondered if you had a similar problem with the flasher units fuse, it would be worth a try before you have to delve deeper.
If you have to delve deeper I would remove the flasher unit and bench check it with two bulbs and a 12 volt supply to make sure it operates on the bench, then check all the flasher circuit earths before heading into the wiring.
Hope you fix it
Alont
