about 2 month ago my clutch pedal felt soft one night , so i go and look under the hood and find like two drops of fulid left. took it in and found out that the clutch line was leaking, they almost didn't cover it thru my warrtey." Your car is to moded" i have home made short ram and exhaust, plus neons. any way has any body else had this problem
i had a problem w/ air in my line and i didnt know til i couldnt get it out of gear and the pedal went to the floor the second i barely touched it.  thank god it was only air and all i had to do was bleed the line
as long as your mods arnt associated from the problem they have to replace it regardless if you have mod. if you contribute to the problem then dealer wont replace it
joe kennedy wrote:as long as your mods arnt associated from the problem they have to replace it regardless if you have mod. if you contribute to the problem then dealer wont replace it
yea basically if they can prove that the mod you added caused the damage, well then their ass is clear
sorry to bring this thread back to life but same thing happened to mine gonna check the bleed out the lines in the morning..if thats not it wat else could it be besides the slave cylinder and air in the lines?
