Kiss my ass dude im surious......
So was he. Calm down man. You can use a fork to remove them. I personally prefer the "shop towel" method.
Slide a rag behind the window crank. Work it back and forth. The c-clip will pop out. (This usually only takes a couple seconds.)
Also, you can go to autozone and buy the window crank removal tool for  couple bucks.
You can buy it for a couple bucks at Autozone??  Wish I knew that before I spent $25.00 +/- from Snap-On Tools...  I wish they made everything with a bolt to unscrew, or at the very least a hex nut.  I guess it's the few cents they save...
ouch 25 bux ... if not the towel or the fork method even a fishing line will do its pretty easy ones you do it ones and figure out how tis held on.
