Just wondering how you guys change the spark plug wires on a 2.2L OHV engine. From the top or the bottom?
Also, if someone could give me a diagram for where coolant drain plugs are, I'd appreciate it. Thanks
1992 Chevrolet Camaro RS 3.1L V6 A4- Metallic Green
1995 Chevrolet Camaro Z28 M6- Patriot Red
1995 Chevrolet Cavalier A4- Winter beater/purple
HUH?
The spark plugs and wires are on the side of the block easily accessable from the front of the engine.  Just pull the wire boots up, and replace 1 by 1, make sure you dont change the firing order.
And there is only one drain plug for the 2200. Look in the bottom driver side of your front bumper. There is a little plastic plug, turn it, and coolant will come out of its side.  You might want the passanger side proped up a bit so the coolant goes only in one dirrection.
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
The spark plugs are easy, but replacing them from behind the engine is the part I'm talking about. I can barely see them back there. I might just have to play the "feel around game" with them then.
