I'm not a mechanic, but here's some ideas:
Pull in and out on the tops of the tires; if you notice a lot of movement or a clunking sensation, you may have bad bearings.
You could possibly have thrown some wheel weights, or they may have moved, unbalancing your tires, a tire shop can fix this for a fee.
Bad motor mounts?  One possible way to check for this is to get going a smooth road, put the car in neutral, and let off the gas so the car is idling (or just turn it off, but you will lose power brakes and steering FYI) and see if the vibration goes away.
Bad tie rod ends would have to be checked by a mechanic on a hoist (I think)
Worn U joints in your half shafts might do this too though i'm not sure...
rotate your tires
        my car is a girl because I describe her as sexy, beautiful, hot. I look at her curves, and I caress her body once a week with various soaps and sponges. Also, I get in and out of her every day.
haha or you could have flatspotted your tires like I did. Pulling 180's is not good for the tires and probably countless other parts (or just jamming up a set of tires by yanking the E-brake, or slamming your brakes) do you notice it more, less, or evenly the faster you go?
My tires arent bad but on the highway my car gets a slight vibration that you can feel through the seats
Calvin Di Bartolo wrote:haha or you could have flatspotted your tires like I did. Pulling 180's is not good for the tires and probably countless other parts (or just jamming up a set of tires by yanking the E-brake, or slamming your brakes) do you notice it more, less, or evenly the faster you go?
It's usually on the highway, but then again I drive on the highway 90% of the time, lol. I notice it the most on downhill slopes. Doesn't have to be steep but that's when I notice it most. Not neccesarily when I'm braking to slow down, but sometimes when I'm just letting cruise too.
The Hellserpent
Aiming to be the LARGEST directory of Sport Compact Enthusiasts in the Northeast!
