wierd skipping problem - Maintenance and Repair Forum
Monday, July 25, 2005 5:26 PM
car is a 95 w/2.2 auto.seemed to have developed a slight skip at a idle and when you are on the gas just enough to hold a steady speed.no problems under power though.thought it might have been throttle position sensor so i changed that as well as o2 sens.any one else had similar prob and if so what was the remedy??????
Re: wierd skipping problem
Monday, July 25, 2005 6:52 PM
Hi Rich
I had a similar problem on a '93 auto 2.2 and the local garage correctly identified the Crankshaft Position sensor-a new one eliminated the problem completely.
Mine would miss slightly at idle and a little more noticeably when rolling along with the engine not pulling or on the overrun, accelerating or slowing down there was no detectable miss.
Hope this helps
Alont
Tuesday, July 26, 2005 5:20 AM
thanks, i will check that out.
