Hey guys i need to replace my aft-cat o2 sensor i got the sensor ,what am i going to need for tools and whatnot before i start this job not knowing wtf im gonna need any help or advice is greatly appreciated also is the sensor right out in the open after the cat or is there anything covering it that needs to also be removed?
You should see it quite clearly as something with wires sticking out from the pipe.
I suggest you get an 02 sendor remover socket head.  Its a normal socket but with one side of it cut away , so you can remove it with the wires still there.
YOu might, and i stress might, need a liquid wrench or PB penetrator to loosen it.
Thats about it, the rest should be plug n play.
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
