OKay so the title says it all.  Just had the front end fixed on this car,, ( bought it damaged).  To the best of my recollection, the headlights worked on the way home from the auction.. it is fixed now, and ALL I have is Daytime running lights..  NO high beams, NO low beams... I searched and found some forums that these have inherent headlight issues. Is there a chassis ground somewhere accessable nearby the RF vicinity of the car that may be off? If not, How bad is it to unwrap and locate the problem assuming its in the engine bay headlight harness.
 Sorry for the rant, this car came out great, has 25K miles, and NO HEADLIGHTS...
 /RANT
check each headlight bulb with mine had a bad headlight bulb and a burnt spot in it but i'd also check grounding near the headlights and possibley the DRL relay in the car but tahts the last option i'd do
The DRL runs thru the high beam on the lamp. So you know the headlite harness is fine. My first guess would be the multifunction switch. These Js have a problem with the switch. You're better off just replaceing it.
