Automatic Trans Shifting Hard - Maintenance and Repair Forum
Thursday, August 04, 2005 4:28 PM
Lately my car has been shifting really funny. It is an 98 2.4 Auto LS. Sometimes when I drive it will shift fine. Then all of a sudden, the transmission will start to shift through the gears really hard, and will not downshift to accelerate. Now this problem is intermtent and happens when I am driving normally down the road and when I start it up and drive somewhere after letting it sit. I found that if I park the car and turn it off, and wait a few seconds and restart the car, the transmission will start to shift normally again. My car currently has 117,000 miles on it and this just started happening. I have no fluid leaks or anything. Can anyone help me diagnose this???
MaTtMan
98 Ls AuTo
Re: Automatic Trans Shifting Hard
Thursday, August 04, 2005 4:31 PM
Could be a solinoid in the valve body check it for codes.
Friday, August 05, 2005 10:35 AM
Maybe it is time for an AT oil change????????????
Friday, August 05, 2005 5:13 PM
It's going into "limp" mode, where it boosts the line pressure.. that's what's causing the hard shifts.
There are quite a few problems that can cause the limp (or open loop) mode to kick in.. done any modifications lately? The most common one is with an intake, the IAT sensor not being plugged in properly. Of course, there's a long list of things it could be.
The easiest way to figure it out is to go to GM and have them hook up the Tech 2 to the car and "watch" what the car is doing.. the hard way is to go thru it step by step..
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/misc/redsig.jpg"></a>
Wednesday, August 10, 2005 8:06 AM
Thanks for your input. John, it sounds like you have hit the nail right on the head. I have done any mods at all laterly. This happens while i am driving around alot of times. It could be possible that my IAT or someother sensor is bad. Luckly my friend has access to a Tec-2 scanner. So I should be able to find something out. And Old Wolf your right, I do need do do a tranny service.
Thanks for all your help.
MaTtMan
98 Ls AuTo
Wednesday, August 10, 2005 5:48 PM
Mine has been doing that also!! Mine only has 70,000 miles on it, I was going to go get the Auto transmission fluid changed at the dealership. Would there be any codes in there if the check engine light isn't on though. I have a friend at the dealership where we could hook up the tech 2 to it, so what would I be looking for on it?? Thanks for all the help!!
2000 Cavalier Z24 A4 Green Met.
Wednesday, August 10, 2005 5:53 PM
mine does the same thing also...and finally it threw a code of torque converter solinoid stuck on
If I'm weird and everyone else is weird, does that make me normal?
-me
Versus Motorsports really @!#$ sucks
and so does DHL...but more
Friday, August 12, 2005 7:59 PM
So what would I actually need to do on the Tech 2 to figure this out? Can anyone give me any advice??
Thanks a ton!!
