i need to know how to take off a fender and the front bumper i need detailed instructions
be a little more specific, what car/year.
theres like 3 bolts under the hood, take off the mudflap, if you have it, on mine, 02, theres a bolt behind the corner lens, and open your door, theres an 8mm(on mine) on top
Fender
For the fender you need to take 2 bolts off the hood hinge. all the bolts that run along the top of fender like 3 i think. theres 2 at the bottom of the fender right by tire you have to  look under car. theres 1 in the door jam and another from inside the wheel well. the last 2 bolts do dont remove all the way just loosen them a bit  you have to take off the trim in the wheel well to access the one and to take fender off.
Front clip
Take trim out of wheel well. Take out heedlights to access 2 bolts on each side you can also accesss from inside wheel well. the 2 bolts are like right under your corner lense. then the 4 tabs that run along the impact bar.
Hope that hopes
buy a haynes/chilton's  manual, will probably be used alot
ToBoGgAn wrote:buy a haynes/chilton's  manual, will probably be used alot
just got one today thanks for the tip lol
