Hi guys,
My rear reverse lights on my 2001 zv24 dont light up. I cheked the light bulbs in the rear and the look fine and not burnt.
Is there a fuse for the rear reverse light? the diagram on the fuse box cover dont help much on tracking the right one and i dont want to go thro all of them.
Does anyone know which fuse it is?
Thanks
Nope. fuse ain't the problem try your back up light swith its prob bad. Dealer like $25.00 and ask them to pull up a picture so you can see where its located.
Man your like the 5th one with this prob this month! Please dont think I'm being rude
cause I'm not.
Good luck let me know if it worked out ok
Reverse switch is out on the trans. Or fuse blown in the body harness somewhere.
Tach Out Motorsport
Http://www.team-tachout.com/
Falmouth,VA
Mines having the same problem.
www.houston-domestics.com
Ok so the reverse switch is located on the tranny. Can i see it myself if i got under the car? Like if i can located i can change it myself.
Remove the drive side front wheel look into the engine bay its right under the shifter linkage, Well it is on mine not sure if yours is the same tranny. Thats why I said what I did about the dealer and having them show you a picture .
Ok thanks jackalope,
Im putting it on the lift tomorrow. Should be easy to locate the switch.
does anything leak out when you pull out that switch?
New Picture comming this summer.
