Weird Headlight problem - Maintenance and Repair Forum
Friday, August 12, 2005 9:05 PM
This has been going on for a while, but I was wondering if there is a quick fix on this... When changing my headlights to the on position, they don't turn on... parking lights turn on, but the full headlight setting does nothing, and the DRL's stay on. I can turn on the brights and drive that way, and before I pull the stick forward enough to turn on the brights, the regular headlights will come on. I can wedge a piece of paper in there to keep the headlights on, but it hinders my ability to use the turn signals without cutting the headlights off.
So I guess with that said, I'm wondering what I should look at in the wiring, and how to I correctly remove the plastic around my steering column?
__________________________
1998 Cavalier Z24
Re: Weird Headlight problem
Friday, August 12, 2005 9:42 PM
similar thing happened 2 me my brights only worked when i held the switch dealer fixed it 4 under a 100$
Saturday, August 13, 2005 7:33 AM
The same thing happened to me in January. I just drove around using my brights for a while, then they wouldn't come one anymore. It was the headlight switch (turn signal arm). Just go to the junk yard and pick one up. They can be had for around $35 and they're very easy to install - takes less than 10 minutes.
Saturday, August 13, 2005 12:28 PM
alrighty then, I'll see what I can find... Is the arm the same for all 95-99 Cavy's, or do I have to find a z24, or certain model (in case I have trouble finding the same year, model, etc...
1998 Cavalier Z24
Sunday, August 14, 2005 10:43 AM
My sedan and my buddy's Z24 headlgith switches are idendical. I have a 97 2.2 and he has a 99Z.
Sunday, August 14, 2005 10:45 AM
any third gen switch works they are all the same you just have to choose between cruise and non cruise
<a href="http://www.cobaltss.net/forums//index.php?referrerid=37" target="new"><img src="http://registry.gmenthusiast.com/images/tgmtzmx/SatchmoeSigJBO.jpg"border="0"></a>
