High Oil Pressure - Maintenance and Repair Forum
High Oil Pressure
Friday, August 19, 2005 8:56 AM
Has anybody had any oil pressure problems with the ecotec motor. I just hooked up an oil pressure gauge on my o3 cavalier and at idle it is reading 75psi. At 2000 rpm it reads 100 psi. I got the same reading from a mechanical gauge as well as the electrial gauge.
Re: High Oil Pressure
Friday, August 19, 2005 12:21 PM
Is the engine cold when you get this reading? My car (2.4l) reads around 80 when it is first started but then after it is warmed up it reads about 25 - 30.
http://members.cardomain.com/scrawnyguy18
Saturday, August 20, 2005 7:38 AM
I get the reading when the engine is warm
Tuesday, August 23, 2005 9:53 AM
hey guys just wanted to let you know that the ecotec motor is made to produce high oil pressure. After getting on alldata I found out that oil pressure @ 1000 rpm is between 50-80psi
