I havent had much time to work on my car as all I have been doing is working but I was able to find my no start problem.  I am not getting any fuel through the injectors when I try and start the car but Im not sure if its an injector or fuel line problem.   How can I test to see if the injectors are ok or if there is a clog somewhere in the fuel line?  I hear the fuel pump when I turn the key so that probably isnt the problem.   Any help is appreciated!!
Thanks
RIP 3-23-05
did you change the fuel filter lately?
you can disconnect the line from the fuel filter going into the engine & put the key to on...u should have a steady stream of gas ... or just do the filter change right now & try to see if that solved the clogging problem... that's a good start.
