I had a problem with the water pump leaking i believe. I also heard the coolant is not that good for the car. So i now mix it with more then 75% water. Never have had the car leak a drop since which was a few months ago. Anyway i want to drain it all when storing it since i dont need it to freeze and cause more problems.
thanx
Jon
The front of the radiator on the driver side.
My Car
or you could pull a hose.
add a additive to it to help keep it from freezing
