Turn signal problem - Maintenance and Repair Forum
Turn signal problem
Sunday, September 04, 2005 11:23 PM
Hi ppl,
The last night noticed at the cluster that the left signal arrow (when I activate it of course) was flashing quickly than normal... took a look at the head signal lamps and were flashing at the same speed (quickly)... and the tail ones were not flashing... do anyone know what's going on? TIA
btw the right signals are working fine
Re: Turn signal problem
Monday, September 05, 2005 12:14 AM
Someone can correct me if I'm wrong. But if your right signals are fine, your front left flashes quickly, and your rear left doesnt flash at all, then you just need to replace the rear left bulb. Its a saftey feature to let you know that you have a turn signal not working.
Monday, September 05, 2005 6:24 AM
david pethe wrote:Someone can correct me if I'm wrong. But if your right signals are fine, your front left flashes quickly, and your rear left doesnt flash at all, then you just need to replace the rear left bulb. Its a saftey feature to let you know that you have a turn signal not working.
I will correct you. Its not a safety feature, its because the current is going to the working bulb making it blink x2 than normally.
But you are correct he does just need a new bulb.
Monday, September 05, 2005 8:06 AM
Wow! Thank you so much guys!!!! I got it fixed now!!!!
Monday, September 05, 2005 9:19 AM
yeah, the relay needs a certain amount of resistance to blink at a set rate, if one bulb is out, there is less resistance, therefore it will blink faster.......or something along those lines
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Monday, September 05, 2005 8:00 PM
I stand corrected. Good luck with that turn signal ... should be an easy fix.
Monday, September 05, 2005 9:04 PM
switch to synthetic blinker fluid.....you prolly have a bad hose
Not unintentionally accelerating since 2009!!!!
Monday, September 05, 2005 9:05 PM
same thing happend to mine and i thought it was the bulb but the bulb was fine. i had to clean out some of that gunk inside where the bulb sits and now it works fine
Monday, September 05, 2005 9:12 PM
There is a recall on my car for a similar problem. The way to fix it take some dilectric grease like for spark plug boots, and coat the socket, and install a new set of bulbs.
While you have it apart, do both sides.
Tuesday, September 06, 2005 3:11 PM
KandyMan...Das Deutsche. wrote:switch to synthetic blinker fluid.....you prolly have a bad hose
Which brand is better? "BlinkTilBlind" is the only one available around here... Is it fine? Abt the hoses, made a check all the dawn and everything seems fine... I'm thinking seriously to rent a scanner to check those...
Tuesday, September 06, 2005 4:07 PM
ONLY USE IT IF ITS THE CLEAR SYNTHETIC NOT THE RED SYNTHETIC...THE RED IS MADE FOR FORDS ONLY
Tuesday, September 06, 2005 6:16 PM
make sure you bleed the system when you change it
Tuesday, September 06, 2005 10:35 PM
btw, a technician told me to use the eco-fluid that comes in green... and it's better cuz my car is green... does it make sense?... it's the most expensive, but it's lead-free and will help to protect the planet including the ozone layer!
btw is there any cap or system to bleed the fluid? is the liquid harmful?
