cylinder 1 misfire code - Maintenance and Repair Forum
Saturday, September 10, 2005 9:42 AM
I have a 1996 Cavalier Z24.
I have searched about it and everyone seems to have differnent things. I don't want to try the "shotgun" approach and replace everything, which it seems like everyone else is doing. Does anyone have some ideas? Thanks in advance
Re: cylinder 1 misfire code
Saturday, September 10, 2005 10:10 AM
change spark plugs, or check and regap them. run some seafoam thru your gas tank.
or change the coil pack
Saturday, September 10, 2005 10:41 AM
I have yet to see this seafoam stuff yet folks talk about it all the time.
Was company makes it/what does the bottle look like?
-M
Saturday, September 10, 2005 10:49 AM
red and white metal canister, says SEAFOAM. Mix in crankcase, gas, good stuff 2 have
Saturday, September 10, 2005 4:10 PM
ok well i checked the coils by ohming them out and they ohm into the range that they are supposed too. The spark plugs are gapped correctly and appear fine. i changed the fuel filter. I found the coil cover cracked (the white thing) and replaced that. i used sea foam and still it doesn't make it any better. Does anyone else have any idea what is happening? I tried using the troubleshooting section on the haynes book and still have have to look at the fuel injectors. The only other thing that i see that it could be is the ignition control module....all help will be greatly appreciated. Thanks.
Sunday, September 11, 2005 6:45 AM
try the changing your spark plug wires first , that is going to be alot cheaper than the module , trust me !!!
http://www.danasoft.com/sig/lman1.jpg
Sunday, September 11, 2005 9:26 AM
2.4L don't have spark plug wires
Monday, September 12, 2005 8:28 AM
MadDog, I had the same problem with my 96 Fire....turned out to be an injector ground trigger wire from the PCM to my # 2 injector had rubbed through on the chassis and shorted to ground. the injector was staying wide open, dumping fuel into the cylinder. Too much fuel, it could not spark, so it flagged a missfire... easiest way to check is to unplug the PCM harness and the plugs on the injectors, use a DMM and test for anything showing a short to ground. It just may be your problem!
If at first you don't succeed, destroy all evidence you tried!
