Thermostat Gasket and O-ring? - Maintenance and Repair Forum
Thursday, September 08, 2005 9:59 AM
Hey all... I did a search and didn't find anything. So here goes.
I have a 95 2.2 cavalier.
I noticed that I had a small coolant leak (above the headgasket) which was a good sign. I noticed that it was leaking around the thermostat housing. So I went to the local parts store and purchased a new thermostate and gasket. The parts guy told me that I also need the o-ring.
I have installed thermostats before, with the gasket, but never an o-ring.
Does anyone know where this o-ring goes? Although its a $2.00 part, I want to make sure that I cover all my bases.
Lefty.
Re: Thermostat Gasket and O-ring?
Thursday, September 08, 2005 11:30 AM
Yeah, There's a gasket for the housing and the o-ring the stat sits on.
Sponsored by:
JLCaudio.net
Thursday, September 08, 2005 1:20 PM
OKay... but where do you put the gasket for the housing. Is it where the thermostat is, or inbetween the housing and the head?
Saturday, September 10, 2005 12:26 AM
The black rubber o-ring with go around the edge of the thermostat, Then to attach the paper gasket to the outlet connector, tighten the bolts and upper rad hose then youre good to go.
Saturday, September 10, 2005 1:25 AM
when u take it apart you should see where it goes, you could probably use the old one anyways.
-Borsty
Saturday, September 10, 2005 4:37 PM
The rubber one is usually good, the paper gasket will tear and you'll need a new one. make sure you clean both surfaces good before you put the new one on.
Sponsored by:
JLCaudio.net
