well as some knew my car is getting a new heart
which includes
Dual spring valve springs-----------------GM Racing
titanium valves-----------------------------GM Racing
titanuim retainers--------------------------GM Racing
eagle head studs---------------------------Eagle
eagle connecting rods---------------------Eagle
eagle forged crankshaft-------------------Eagle
Weisco 8.9:1 pistons-----------------------Weisco
and of course I am going to get the head port matched and polished.  I can't wait to get here broken in.  Expect to see her hit the track at the Import FaceOff 12/16
Then you can get your rematch with tyler
I asked him if he wanted to go again since I missed a gear.  That was a crappy track.  come to import face off  12-16 and I will show you the difference
Wait till I get down there, then you and I can race
^ that sounds like a good match up
hopefully u get soem fuel mods too so all that wont go to waste haha i wanna see it run at least a low thirteen ben no more fifteens!
lol I like that  wasp vs Bumble Bee
well an update on my part list.  for some reason I decide that if I am in there I might as well do it right.
harden steel seats--------------------------gm racing
nuetral balance shafts---------------------gm racing
upgraded oil pump--------------------------gm racing
adjustable cam gears----------------------gm racing
weisco head gasket------------------------weisco
steel water pump----------------------------oreillys  (I didn't know our stock one has plastic fins)
termostat---------------------------------------oreillys
lower crank case bearing bolts----------gm
port, polish and wash-----------------------Clays machine shop
all new gaskets-------------------------------Flatlander racing
timing chain------------------------------------flatlander racing
main bearings---------------------------------gm
rod bearings------------------------------------gm
wow I still dan't believe I am doing all of this.  But it is coming along well.  Just taking my time with it.
 no one cares.  I figured someone would reply
im still trying to figure out how you blew the welds off your intake...
Doin it Texas Style...
When your done we can do mine
[quote=Ozzie�]im still trying to figure out how you blew the welds off your intake...
I actually did.  when I had pulled out my plastic intake manifold to put the SAAB one in I found that it was cracked on the plastic intake welds
oh AND wasp
NO way.  not for a while this motor has taken it out of me.  I am exhausted  SO many measurements and clearance checks then having to get all the parts.  and find out I need others.  I will be so glad when it is done.  that is why I went ahead and spent more then expected on it to make sure it never has to come apart again.
Eco you should have seen the LS1 I built about a year ago for my fiero that motor tired me out. It also drained my bank acount until there was nothing left.
I can definatley to see where your coming from.
In the end though its so worth it, more boost or a good N/A build(my LS1) takes time but in then the smile can only get wider.
Josh Cortez wrote:In the end though its so worth it, more boost or a good N/A build(my LS1) takes time but in then the smile can only get wider.
my theory is if modding takes longer during the process then it will be better in the long run
That's the truth. You don't measure or gauge once you do it at least 20 times. Plus taking your time you really learn to appreciate the vehivle itself when its down.
yea and torque ever bolt that is put with the oem torque number
I don't know I said torque.
So true I remember I went and bought an electric torque wrench specifically so I don't overtorque anything, best 100 buck I've spent on a tool. You just put in the torque numbers you need and then start wrenching it starts to beep when you've got the right spec.
kool, get it done before july of next year and bring it to the big bash in ohio.  me and pj will want to race you.  got huge plans for the eco and ive already got quite a few parts for it
