Changing Directions. Stuff For Sale. - South Central Region Forum
Sunday, November 15, 2009 12:30 PM
Having a small part out. Changing directions with the car. Most parts are used except fot the valve
springs, bearings and couplers. I'm open to offers and trades so prices are negotiable. Let me know
what you've got. Pics available upon request.
Cavalier
95-99 cavalier 2.2 intake w/ AIT sensor -filter $20
95-99 cavalier brake calipers w/ hardware and semi-metallic pads $30
95-05 cavalier 4t40e trans mount $20
95-99 cavalier 3 speed trans mount $20
95-99 cavalier 2.2 ohv front motor mount $10
95-99 cavalier 2.2 ohv alternator $20
02-05 cavalier 2.2 ecotec throttle body -tps $20
95-02 cavalier radiator cover $5
95-99 cavalier gauge cluster w/o tach $15
95-99 cavalier 3 speed shifter assembly $15
Grand Am
4t45e side cover $20
3400
3400 exhaust manifolds w/ crossover $30
3400 coils w/ icm and ac delco plug wires $40
3400 throttle body -no sensors $20
3400 alternator $30
3400 p/s pump$20
3400 gear reduction starter $30
3400 egr valve $10
.10 over crank bearings $40
WOT-TECH 3400 Ishihara-Johnson crank scraper $50
3400 windage tray $15
3400 pistons and connecting rods w/ new standard bearings $70
3400 p&p cylinder heads w/ port matching (still at machine shop) stock valves and springs $150
3400 lower intake $30
3400 block -hot tanked,honed, glyptal coated and machined oil passages, new cam bearings (prefer local
pickup) $120
3500
3500 upper intake $90
Comp Cams 26915 springs -new $110
36# GTP injectors w/ pigtails $100
Misc.
Holset hx30w turbo for parts only -broken shaft $40
2 used 4 wire 02 sensors $10 each
20 3" diameter x 6" length silicone couplers $5 each
Re: Changing Directions. Stuff For Sale.
Sunday, November 15, 2009 7:47 PM
can u post a pic of the intake?
Monday, November 16, 2009 1:20 PM
hey billy, if you have some lowering sprins, i will take them.
Monday, November 16, 2009 5:11 PM
I don;t have any. But I need a set for a grand am...hehe
Monday, November 23, 2009 4:55 PM
New updated list. Make offers. lol
Cavalier
Grand Am
3400
pickup) $120
3500
3500 fuel rail $30
3500 exhaust manifolds $40
misc. other 3500 junk (let me know what you need)
Misc.
4 used 4 wire 02 sensors $10 each
Thursday, November 26, 2009 4:28 PM
LOWER PRICES!!!
Cavalier
95-99 cavalier brake calipers w/ hardware and semi-metallic pads $25
95-05 cavalier 4t40e trans mount $12
95-99 cavalier 3 speed trans mount $12
95-99 cavalier gauge cluster w/o tach $10
95-99 cavalier 3 speed shifter assembly $10
Grand Am
4t45e side cover $10
3400
.10 over crank bearings $25
WOT-TECH 3400 Ishihara-Johnson crank scraper $45
3400 pistons and connecting rods $45
3400 p&p cylinder heads w/ port matching (still at machine shop) stock valves and springs $offer
3400 lower intake $20
3400 block -hot tanked,honed, glyptal coated and machined oil passages, new cam bearings (prefer local pickup) $120
3500
3500 upper intake $70
36# GTP injectors w/ pigtails $75
3500 fuel injectors w/ harness $40
3500 fuel rail $25
Misc.
Holset hx30w turbo for parts only -broken shaft $30
20 3" diameter x 6" length silicone couplers $4 each
Thursday, November 26, 2009 6:18 PM
WOT-TECH stage 3 turbo cam 1617 grind $250
hybrid 3400 lifters w/ ls1 springs installed $40
Tuesday, December 01, 2009 7:08 PM
Cavalier
Grand Am
3400
3400 front timing cover w/ water pump $15
3400 oil pan $25
3500
3500 fuel rail $25
3500 exhaust manifolds w/cats $40
3500 crank pulley $10
custom pushrods for the cam above $100
Misc.
Wednesday, December 09, 2009 5:25 PM
Cavalier
95-99 cavalier 3 speed trans mount $10
Grand Am
3400
3400 oil pan $25
3500
3500 fuel rail $25
Misc.
Thursday, December 10, 2009 5:12 PM
Thursday, December 10, 2009 6:30 PM
Hi Yolie!
Friday, December 11, 2009 4:49 PM
Hola Billy! Hows Kim? ...what r u driving now?
Friday, December 11, 2009 5:05 PM
Driving the z24 right now. Kim's good. She's got an 09 Lexus rx350.
Monday, December 14, 2009 9:45 AM
z yaaaa Online
u sell that 3400 throttle body?
Stand in the corner and SCREAM with me!!!!
Tuesday, December 15, 2009 4:32 AM
I did. Mark at mp performance bought it. Sorry man.
Thursday, January 07, 2010 10:02 AM
Cavalier
95-05 cavalier 4t40e trans mount $10
Grand Am
3400
3400 oil pan $25
3400 crank (polished and checked by machine shop)$40
3500
3500 fuel rail $25
Friday, January 15, 2010 7:59 AM
Does your guage cluster have a digital odometer on it? Is it for a 5speed? If so I'll take it as long as it works.
Sunday, January 17, 2010 5:53 PM
Manual odometer...automatic. sorry.
Cavalier
Grand Am
3400
3400 oil pan $25
3400 block -hot tanked,honed, glyptal coated and machined oil passages, new cam bearings (prefer local pickup) $120 PENDING
3500
3500 fuel rail $25
WOT-TECH stage 3 turbo cam 1617 grind $225
custom pushrods for the cam above $90
Tuesday, February 02, 2010 7:04 PM
Cavalier
95-99 cavalier brake calipers w/ hardware and semi-metallic pads $20
Steelies with new rubber $90
Grand Am
Alero alloy wheel $10
(3) 18" Forte Black Russ Wheels 5x100 and 5x114.3 MAKE OFFER
3400
3400 oil pan $25
3400 exhaust manifolds $40
3400 exh. manifold covers ceramic coated in silver
3500
3500 fuel injectors w/ harness $30
3500 fuel rail $25
WOT-TECH stage 3 turbo cam 1617 grind $200
custom pushrods for the cam above $70
Misc.
Holset hx35g turbo $120
bolt or weld on 4" chrome exhaust tip $10
Make me an offer guys. I'll consider anything at his point. Even trades. Let me know what you've got.
Sunday, February 07, 2010 7:57 PM
Pics can be seen here.
Monday, February 08, 2010 7:56 PM
Cavalier
Grand Am
3400
3400 oil pan $25
timing cover gasket set TCS45828 $5
oil pan gasket set OS20668R $12
3500
3500 fuel rail $25
Misc.
Thursday, February 18, 2010 7:00 PM
Cavalier
95-99 cavalier brake calipers w/ hardware and semi-metallic pads $15
Grand Am
(3) 18" Forte Black Russ Wheels 5x100 and 5x114.3 Cavalier and Grand Am w/tires MAKE OFFER
3400
3400 oil pan $20
3400 exh. manifold covers ceramic coated in silver $15
3500
3500 fuel rail $25
Misc.
6 used 4 wire 02 sensors $10 each
Pics can be seen HERE
Wednesday, April 21, 2010 7:50 PM
Make an offer guys. Getting ready to throw all this stuff out and would like it to go to a good home.
Cavalier
95-99 cavalier brake calipers w/ hardware and semi-metallic pads $5
95-05 cavalier 4t40e trans mount $5
95-99 cavalier 3 speed trans mount $5
95-99 cavalier 2.2 ohv front motor mount $5
95-99 cavalier gauge cluster w/o tach $5
Grand Am
(3) 18" Forte Black Russ Wheels 5x100 and 5x114.3 Cavalier and Grand Am w/tires ALMOST FREE!!! $50
3400
3400 oil pan $15
.10 over connecting rod bearings $20
3500
3500 upper intake $50
3500 fuel injectors w/ harness $20
3500 fuel rail $15
3500 exhaust manifolds $8
WOT-TECH stage 3 turbo cam 1617 grind $180
Misc.
6 used 4 wire 02 sensors $6 each
3" diameter x 6" length silicone couplers $2 each
Wednesday, April 28, 2010 5:00 PM
Cavalier
Grand Am
3400
3400 oil pan $15
3500
Misc.
3" diameter x 6" length silicone couplers $3 each
http://s61.photobucket.com/albums/h73/92cavquest/stuff%20for%20sale/
Wednesday, April 28, 2010 6:50 PM
Do you have a more pics of your 18' rims beside that photobucket pic?
www.gmofhouston.com
