how much would it cost to have a 2.4 block bored .020 over and machined to fit the 2.3l oil pump??
thanx!
i had the same idea and mine is in the machine shop as we speek......i will let you know the tally by mid next week........
Cool! i thought it would be more expensive.
thanx guys!
let me know Daniel!
go dry sump...cooler....better performance...and u get rid of a ton of weight
Black 97' Z24
Blacked Out and Lovin' It...
"Z Yaaaa"
but how much does that cost? what is involve?
To do the oil pump conversion, they have to drill a new oil feed gallery, plug the old one off, drill two holes to bolt the oil pump down, press a sleve into the one new oil gallery, then you have to mount the windage tray, and do some grinding and fitting and welding to the oil pan to make it all fit.  Not really sure how much I paid, I had a lot of engine work done when mine was put all together, but it may be quite a bit.
http://www.saskjbody.org/
http://www.cardomain.com/memberpage/449879/1
yeah welding the oil pan alone is an intricate task I would never want to take on.  You have to be really careful not to warp the soft aluminum pan...that would make it junk on the spot.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
Yeah and buy a new pump.  Cheapest I have found thus far is www.summitracing.com at $104 and some change.
-da chinchilla
