HO fuel Injectors?? - Performance Forum
HO fuel Injectors??
Wednesday, March 09, 2005 8:36 PM
I was wondering if putting the HO fuel injectors on my 2.4 would help me out. I am putting the HO manifold and TB on next week, so would the HO injectors help me out or hurt me performance wise???
and if they would help could i use the ones of the VIN "A"?
Re: HO fuel Injectors??
Wednesday, March 09, 2005 9:23 PM
anyone?
Thursday, March 10, 2005 12:23 AM
Ho engine = Vin A
and No you can't you have a 2000. you have High impedence and Ho are Lo.
Gilles
2.3 Ho
Thursday, March 10, 2005 6:44 AM
what does it mean that i have high impedence??
Thursday, March 10, 2005 6:52 AM
I know probably 10 different people that run Low Impedance injectors on a High Impedance system and they are just fine. Sunfighter GT, hell any of the 99+ guys who are running Brown Tops, which is a LOT of people.
The impedance dictates what type of injector you have.
Low Impedance:
Also known as saturated injectors. If you measure the resistance through the injector you get like 3-6 ohms.
High Impedance:
Also known as peak and hold injectors. If you measure the resistance through the injector you get like 12-16 ohms.
You can run low impedance injectors in a high impedance system, but not the other way around.
Thursday, March 10, 2005 7:02 AM
^^ I think that you got "saturated" and "peak and hold" switched around there
'99 2200 LS CX1 Sport
Thursday, March 10, 2005 7:13 AM
I wouldn't put it past me
Check out http://www.rceng.com for more information about injectors.
Thursday, March 10, 2005 7:49 AM
the biggest problem with the older injectors and putting them in the 99-up is the plugs you gotta cut and splice new ends for the injectors
there are injectors that are larger with the stock plug for the 99-up
Thursday, March 10, 2005 7:55 AM
so would it be worth the swap are just a waste of time?
Thursday, March 10, 2005 8:06 AM
On an NA car, its really not worth it to upgrade the fuel injectors.
