Here are some questions I have about the 3.8 swap.
1.  If you use the 4t65e (I think thats the right one) tranny will it fit?  I know the axles won't and will have to be custom.
2.  If you use the auto and use the stock 3.8 ecu can you still hook up the 2.4 ecu to run the abs or will the 3.8 ecu freak out because the wheel speed sensors aren't showing anything?
3.  What happens with the air bags?  Are they controled through the 2.4 ecu or some other control?
4.  I know I heard someone makes the "box" that the engine mounts to.. how much is it?
Thanks for the info!
"Fu'k displacement, I'd rather be blown."
