i am confused about the difference intakeslike AEM require my car to have ABS....it doesn't have it and i am wondering will it still fit my car
set the example, never let the example set you.
I have weapon-r dragon intake and it works fine. Intakes are generally the same and usually work the same way.
When the AEM intake was released for the eco it was designed to mount on the abs computer. Then AEM redesigned the intake mounting later on and now it mounts to the strut tower. If you still need help, call AEM and ask them they will tell you that the later revision will work with abs/non-abs.
_____________________________________________
94 Honda Del Sol
thanks for the help
I love mine!
New Picture comming this summer.
I got the AEM, but when you take off the stock airbox, you also take of the mount for the clutch fluid bottle. what did you do with it? (if you have a clutch that is). I just have mine hanging from a wire running alont the top of the firewall.
