how do you remove the intake bong thing
i already searched and i came up with nothing
i hate when people just say search , if i knew how to find it i wouldnt of asked
Jack up the driver side of your car, and make sure your hood is open too.
Remove the inner fender liner. And remove your driver side headlight, if you have a sunfire. Just makes it easier.
The bong is attached to the Washer fluid resivior. There are 5 bolts holding them inplace at least on a sunfire. And 1 is a real pain to get too, Its under the bong on the left side under a wiring harness.
Just remove all the bolts, and yank real hard.
When it eventually pops out, you will see the 1 bolt that connects the washer resivior to the bong. Remove it, and put the resivoir back on. And put everything else back to gether. Simple.
true.
Cannon fodder is my daddy.
99redz24 wrote:did not search hard enough
Your still wrong. The tuner tube is not the air bong.
true.
no i am right, all he has to do is click on number 9 under the All J-Body Applications
My bad, i miss read it. Sorry .
true.
thanks for the help guys, i already had my bumper and fender wells off the car cause im fixing the front lip on my bumper , the clips came off on one side, so i thought well since i got all the stuff off i might as well remove the bong thing, i just have a short temper and i got stuck on one bolt and i wanted to throw it in the road and give up , but i finally got it off...
thanks allot for the step by step
