I had been running a GP on the Custom Car Grills pulley, but it failed due to lack of interest. So as of now, RSM is the only place to get one.
You still might be able to get one directly from CustomCarGrills.com
Thats what I did.
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
^i asked they want like 10 buyers first. i dont know why they just dont start making them. if they are $120 then alot of ppl will be buyin them period. i hate when we have to run this GP just to get ppl to buy a pulley. im not saying there a bad idea but come on its a friggin pulley!
<img src="http://registry.gmenthusiast.com/images/jiggaman/personal_pic.jpg">
stock belt works... use a long handle 3/8 drive ratchet in the tension to get the belt off, then a couple little 7 MM screws in the passenger side wheel well / engine cover, then its on big bolt going through th pulley, remove the bolt (you migh want to leave the belt on till you break the bolt loose cause its gonna wanna spin the engine) once the bolts out the pulley practically falls off (gentel pulling makes it pop right off) its very very very easy, if you have the tools you need in front of you you could have it done in like 10-15 minuets
I must say, I installed mine myself and it was very simple. There was detailed directions written up somewhere. But Putting the belt back on was no problem, justget it all lined up and tighten up the tensioner then slide it on.
I think I got the last one they had. I even got a little discount because it had a tiny little scratch. (hardly noticeable)
Good product tho. No problems 20 thousand miles later. And for $120!!! thats a deal!
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
I have the RSM im happy with it
$120? I ordered one for my 2.4 and it was $80
