Exhaust help, Used header need to clean flanges - Performance Forum
Wednesday, June 22, 2005 6:09 PM
I bought a used RK 421 header and I need to clean it up so I can put new gaskets on it when I install it. Besided just using carb cleaner to get the carbon off the flanges, what shoudl I do to clean them.
I was thinking maybe a scotch pad, but would it hurt to just get some 300 grit sand paper and a flat block and smooth them down? They are a little dinged up in a few places I figured that couldn't hurt it. Im talking more about the downpipe flanges than were it actually mates to the motor. Would it be a good idea to do that too?
Re: Exhaust help, Used header need to clean flange
Wednesday, June 22, 2005 6:12 PM
Thats all id do because once you replace thee gaskets it should seal up pretty good.
Wednesday, June 22, 2005 6:30 PM
If you have air tools a nice angle grinder with a sanding disk on it is great for things like this, and also great for cleaning up rotors for doing brake jobs also.
Wednesday, June 22, 2005 7:15 PM
The flanges look like they are coated with the ceramic paint so Im not sure If I want to sand it down because of rust. I suppose it wont matter once I get the gaskets on good and tight.
Wednesday, June 22, 2005 7:38 PM
yeah just sand em nice and flat and you'll be good to go
Brian
