more problems just found out my coldair filter fell off it rained heavy acouple days ago engine runs fine but dont know what i sucked in should i engine flush i puit the new shell v power gas in to help clean things up any suggestions?
did u suck something into your engine?
well, as long as you're SURE its running fine, you should be ok.  in all honesty, a tiny amount of dust or a little water wont kill an engine.  maybe try some of that stuff you can put in with a full tank to help "heal" an engine.. some of that fuel system cleaning stuff.  other than that though... not much you can do.  its very unlikely something is wrong, if you havent noticed it.
go by a can or 2 of seafoam. run a batch in your gas tank and a batch through your crankcase (pour it right in your oil). you can do both at the same time. i think you can go a whole can in each. that stuff does wonders, even if you don't "have problems". it's just good maintenance. I run some through every time i change my oil. And if your fiter completely fell off and the car is still running fine you have no problems. Just get a new filter on it and make sure the hose clamp is TIGHT.
