fuel injectors? - Performance Forum
fuel injectors?
Tuesday, July 26, 2005 7:15 PM
i was wanting to know know what the stock size for the fuel injectors are and if I put 32lbs injectors in do I need to upgrade other thing or can I get a hp gain from just that ?
( i have a cold air and cat back borla exhaust )
Re: fuel injectors?
Tuesday, July 26, 2005 7:17 PM
oh I forgot its for a 2004 cavalier 2.2 ecotec
Re: fuel injectors?
Tuesday, July 26, 2005 7:44 PM
the stock injectors on the ecotec are pretty damn good. until you start running lean, you don't need any new ones. if you went boosted, or did a HEAVILY modified n/a engine, then you would need injectors.
Re: fuel injectors?
Tuesday, July 26, 2005 10:36 PM
if you go forced induction, you are good on stock internals up to about 6 psi. it all depends on what total power you intend to make, to figure out what size injectors you will want if you replace them.
Re: fuel injectors?
Wednesday, July 27, 2005 12:04 AM
stock is like 14 or 16 lb/hr. good to id say 200HP with some tuning.
i have 32lb/hr (330cc's) in my car but im running 8 pounds of boost everyday and 10-12PSI at the track
5K PB: 24:50
10K PB: 54:26
Re: fuel injectors?
Wednesday, July 27, 2005 10:37 PM
hypsy wrote:stock is like 14 or 16 lb/hr. good to id say 200HP with some tuning.
not bad times at all for stock internals. i commend you.
Re: fuel injectors?
Wednesday, July 27, 2005 10:57 PM
stock should be more than that....
2200;s are 17lbs per hour, and i know the 2.4;s and 2.2 ecotec should have more than that right?
also depends on the psi you test em at i believe.
Re: fuel injectors?
Wednesday, July 27, 2005 10:59 PM
Topher McKenzie wrote:i was wanting to know know what the stock size for the fuel injectors are and if I put 32lbs injectors in do I need to upgrade other thing or can I get a hp gain from just that ?
also an intake and exhaust... you really have no need at all to worry about injectors...
not even close really. basic boltons the car can support small stuff.
