Is it possible to bore out the stock 52mm TB to 59mm? I heard that it isn't, but what other TB on a cavy would work that you could bore out to 59mm to make it fit on a 2200 engine?
not sure how far you can bore your tb out , you can borew it out to whatever size ya want as long as ya dont #1 bore thru the wall , #2 you dont make it oblong ,
as long as you can make a plate for it and you dont go thru the ther side walls go for it ........im no mechanic but i have bored one out to 56 mm with no issues , use common sence ............or pick a tb up from a junk yard and try it ...........
<img src="http://www.bluezone.galaxy99.net/cavalier/imanit2.jpg">
been a long winter.....but summer is on its way !!
