just as the title says im just wondering which ford cars came with the brown tops, i have a set of them but i need the clips, i have a huge pic a part here and can get em really cheap so if i can figure out which cars they came from ill check there before dropping the 50 bucks on new ones from Ford, any help is appreciated, thanks guys.
this belongs in other cars
also check a ford forum
ummm
ford green, red, and brown top injectors are commonly used on our jbody cars when guys get serious about performance and do major power adders such as turbo, s/c, or even large shots of nitrous, and i stuck the post in this forum because i figured the electrical guru around here "shifted" might see it and help me out. Anyways anyone know what cars they came on so i can hit up the local junk yard and see if i can find myself a set of clips that will work to splice into my existing fuel injector harness???
im guessing you have a 99 cav , and it has the small plugs on the injectors , if so you need the 98 older plugs , from just about any GM or FORD car
are yellow tops any good, i yanked them off a car a while back i think it says ford on them, but i need clips cause my stock ones were too big
DRIVE HARD OR DONT DRIVE AT ALL!!!
jimmyc99z24 wrote:ummm
sorry then, iapoligize for my moment of newbness.
thanks for the help guys, yes my car is a 99, i can find pre 98 cars all over so thats easy enough, i'll go grab myself a set today
Thanks alot, saves me about 50bucks from ford
