intake size question - Performance Forum
Monday, August 01, 2005 11:46 AM
is a 2 1/8" internal diameter intake big enough for our cars if yes i am starting my custom intake in a couple minutes (hope to get ans answer fast!
Re: intake size question
Monday, August 01, 2005 1:13 PM
Whats the size on the stock one?
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
Monday, August 01, 2005 1:18 PM
it should be just fine......IAT sensor hole is 5/8 inch.....i had to buy a bit just to drill the damn hole for it my custom one...BTW i used 3" for mine
Monday, August 01, 2005 3:10 PM
sunstealth wrote:is a 2 1/8" internal diameter intake big enough for our cars if yes i am starting my custom intake in a couple minutes (hope to get ans answer fast!
most all major brands on intakes are atleast 2.63 inner diameter which is a 2 and 3/4 outer diameter....
2 and 1/8 would prob net you some downlow, but starve up top
Monday, August 01, 2005 5:14 PM
how about a 3 inch like i have???
Monday, August 01, 2005 5:19 PM
good for top end, but low end is diminished cause you slow down velocity....
your stock TB is 52 mm, which is rougly a bit over 2 inches (50.8mm)
3 inche pipe has a diameter of 76.2mm....
so basically you bottleneck air flow down low with a 3 inch pipe....
lots of noise, but not really efficient through the lower half of the power band....
Monday, August 01, 2005 9:16 PM
yea mine is 3" as are most standard intakes. stick with that.
Monday, August 01, 2005 9:21 PM
Dam-it Muffins (Event) wrote:good for top end, but low end is diminished cause you slow down velocity....
damn...well im not having it redone so i guees i'll just live with it
Monday, August 01, 2005 10:17 PM
you can modify that if you wanted.....
Tuesday, August 02, 2005 9:46 AM
by doing what......
Tuesday, August 02, 2005 3:46 PM
making the pipe closest to the TB gradually smaller...
cone shaped reducer from the 3 inch to a 2.75 can actually speed up velocity, and possible you will get more resonance from it at higher speeds, which would allow more air to be sucked in.
