i drive a 1998 2.4L cavalier and am having a little problem with intake installation.
once i remove the stock intake, i'm not too sure what or how i'm plugging the sensors into the new intake.
on my intake there is a tiny rubber hose connected near the end where the air filter is attached (which i am guessing is for the ait sensor?)
on towards the other end, there is a little pipe that sticks out perpendicularly from the intake pipe. my intake came with this L-shaped rubber hose with a metal piece at one end (is this for the pcv sensor?....wtf is the pcv sensor??)
do i just plug the ait sensor into the tiny rubber hose near the air filter and the pcv sensor (when i find it, guessing it's under the "expansion chamber" <-- the i mean factory compartment which the s-tube connected to) into the metal end that L-shaped hose?
thanks again, for any input you can give. where i live no one really works on their own cars and i'd like to start learning somewhere.
what intake you have, and do you have pictures?
I might be wrong but...
The tube is for the crankcase breather, and the little perpindicular pipe is where the AIT sensor goes.
