Does anyone know the answer to this? If you install the MSD and convert to MSD coils and wires can you raise your rev limiter? Or does the computer still have controll over that? Thanks for your help.
KevinP (Stabby McShankyou) wrote:
and I'm NOT a pedo. everyone knows i've got a wheelchair fetish.
the msd will not change your rev limiter thats still controlled through the factory computer only way to bypass that is to reflash the pcm
you can lower it, just not raise it.
megasquirt?
_
2002 LS Sport coupe
QBE (73H 800573D 0N3) wrote:Rodimus Prime wrote:the msd will not change your rev limiter thats still controlled through the factory computer only way to bypass that is to reflash the pcm
or buy my MegaSquirt
MegaSquirt????
New Picture comming this summer.
fuel management
What does the MegaSquirt have to do with the rev limiter? Thanks for the info Rodimus.
john harrington wrote:What does the MegaSquirt have to do with the rev limiter? Thanks for the info Rodimus.
because you cut your injector wires off your ecu and wire it into the megasquirt therefor your ecu has no control over fuel and your rev and speed limiter are gone
LE61T PTE6262 Powered
rev limiter is spark not fuel i thought
Machzel08 wrote:rev limiter is spark not fuel i thought
That's a soft rev limiter.
John Leahy
'01 Cavalier Z24 - 5Speed
MaxThrottle.Com - All makes/models car forum! Everyone is welcome!
