does anybody know if they make an exhaust cut off for the j bodies? i know they dont do that much...but you no the little things count...
those are universal parts from any race place like summit racing....
^answered pretty damn quick. Make sure you get the same diameter as the rest of your exhaust.
oo ok...cuz i didnt really know how to search for them...thnx
why do you want / need a cutout?
no i heard of this part that attaches before your cat like a Y and one way flows thru ur normal exhaust and the other is just an open pipe...but when u pull a lever or flip a switch or sumthin it opens the open end so you get a str8 exhaust when your racing....is there somethin out there like that for jbodies?
Rob Silvera wrote:no i heard of this part that attaches before your cat like a Y and one way flows thru ur normal exhaust and the other is just an open pipe...but when u pull a lever or flip a switch or sumthin it opens the open end so you get a str8 exhaust when your racing....is there somethin out there like that for jbodies?
unless you are turbo'd or running an extreme all motor build, this is pointless. and once again, it's a universal exhaust setup, as long as you order it for your correct pipe diameter.
Spotabee Racing wrote:Rob Silvera wrote:no i heard of this part that attaches before your cat like a Y and one way flows thru ur normal exhaust and the other is just an open pipe...but when u pull a lever or flip a switch or sumthin it opens the open end so you get a str8 exhaust when your racing....is there somethin out there like that for jbodies?
[bold]unless you are turbo'd or running an extreme all motor build[/bold], this is pointless. and once again, it's a universal exhaust setup, as long as you order it for your correct pipe diameter.
true....
not very advantageous if you dont have alot of power... besides alot of noise.
Dam-it Muffins (Event) wrote:Spotabee Racing wrote:Rob Silvera wrote:no i heard of this part that attaches before your cat like a Y and one way flows thru ur normal exhaust and the other is just an open pipe...but when u pull a lever or flip a switch or sumthin it opens the open end so you get a str8 exhaust when your racing....is there somethin out there like that for jbodies?
true....
without boost or HIGH compression... say goodbye torque.
