Msd Coil wiring - Performance Forum
Msd Coil wiring
Wednesday, August 24, 2005 9:42 AM
I read the faq and the top and I still can not figure it out. My stock wires that go to my stock coils only have like 5 wires and the diagram is showing one to each of the eight from the coil. The car is a 02 2200. Is the diagram meant for the 95- 97. I need some help understanding it.
Where you @Karo
http://registry.gmenthusiast.com/images/importkilla32/Bullit.JPG
Re: Msd Coil wiring
Wednesday, August 24, 2005 11:36 AM
you need the msd adapter pieces, which is listed in the parts list in the FAQ... when i wrote that diagram it was for the adapter plates...
if you wanna hard wire it into your ICM, you will need to get a manual and figure out the trigger wires etc....
Re: Msd Coil wiring
Wednesday, August 24, 2005 2:24 PM
Thanks a lot.
Here is another question..
Some local guy has been trying to sell me some coils. But they don't look like anthing other than stock coils with an msd plate on the bottom of them. I assume they are msd stock coils replacements. Are they worth getting (50 bucks) or should I save to and get the blaster coils?
Re: Msd Coil wiring
Wednesday, August 24, 2005 3:07 PM
msd coils should be red..... thats like their trademark color.
considering new coil packs, 8224 if i am remembering right are 40$ a piece, it might be safer to just go new...
Re: Msd Coil wiring
Wednesday, August 24, 2005 9:51 PM
so if i am right, the MSD coilpacks involve no wiring change. they go right in place of the existing coil packs.
Re: Msd Coil wiring
Thursday, August 25, 2005 9:09 AM
Spotabee Racing wrote:so if i am right, the MSD coilpacks involve no wiring change. they go right in place of the existing coil packs.
exactly what i did...unbolt old ones...4 screws...put on new ones...screw...10 minute job
Re: Msd Coil wiring
Thursday, August 25, 2005 10:04 PM
yea, 10 minute job if you have a LIFT. lol. i'm so screwed.
Re: Msd Coil wiring
Friday, August 26, 2005 5:54 AM
Yeah it is a ten minute job if you have the adapter plate like Event said, but without that good luck in ten minutes.
A guy that helped me work on my car has a 2.2 he said he mounted the coils similiar to the way the 2200's are.
Re: Msd Coil wiring
Friday, August 26, 2005 1:32 PM
its not too bad... once you remove the icm, you can relocate it...
granted i have a 2200, i;ve had my icm and coils, rotated 90 degrees facing up on the side of the engine, all the way back by the powersteering pump, stock location, and also near the radiator....
pretty easy to relocate em.
Re: Msd Coil wiring
Friday, August 26, 2005 5:39 PM
so you have to relocate the ICM to install the MSD Coilpacks for the 2.2 OHV?
Re: Msd Coil wiring
Friday, August 26, 2005 6:23 PM
Now, its been a while.. but I'm pretty sure the coils are exactly the same as the factory ones and don't need an adapter plate. It's when you're wiring up the DIS 2 that the adapter plate comes in handy.
Re: Msd Coil wiring
Friday, August 26, 2005 9:31 PM
Spotabee Racing wrote:so you have to relocate the ICM to install the MSD Coilpacks for the 2.2 OHV?
dont have to, but it can make it easier on some...
on the older 2.2;s the icm is behind the engine where the oil filter is..
