Ok, the car is comming along great. Should work by next week, but my only problem, in the stock electrical system : The input from the sensors (Speedo, tach, watertemp) go trough the ECU and gets transfered to a Serial data and then go to the cluster. Problem is, the AEM EMS cannot do that ! My question is, does the OBD1 cluster (95 sunfire) work in the same way ? Or is there any way to make the cluster work in another way.
Thanks !
<img src="http://pages.infinit.net/lbert/signature.jpg">
I don't think the OBD1 cluster works the same way.
No one has a clear answer ??
you can always give it a try
Based on service manual information, all 3rd gen J car instrument clusters recieve temp, speed, oil pressure, and engine speed information through a data line such as the class II serial data or UART data line. You'll need to install aftermarket gauges or find another vehicle to use as a donor.
-->Slow
being that you have the EMS, and no longer have to worry about the Theft Lock....... install some Autometer gauges.........
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
John Higgins wrote:SpeedRacerZ wrote:being that you have the EMS, and no longer have to worry about the Theft Lock....... install some Autometer gauges.........
We have a winner!!!!
which i suppose you'd have to fiberglass a gauge cluster correct?
