Engine Swap - Performance Forum
Engine Swap
Saturday, August 27, 2005 7:42 AM
I have a '96 2.4 with 110 miles on it ........ what should i do im not sure if it can take the mods i want to throw at it 190-215 hp ... if i can find a Junker engine is the swap even worth it?
Re: Engine Swap
Saturday, August 27, 2005 7:45 AM
I assume you mean 110K miles.
You can swap in the 3800 SC V6
the 2.0L Eco SC
the 2.2L Eco
the 2.2L 2200
http://members.rankmyride.com/djtorello
Re: Engine Swap
Saturday, August 27, 2005 7:47 AM
what kind of mods are you thinking?
http://www.helpelijah.com
Re: Engine Swap
Saturday, August 27, 2005 7:49 AM
yea well im planning on using the 2.4 for the swap because it has 150 horsies stock..... unless............. hmmm eco eco
Re: Engine Swap
Saturday, August 27, 2005 7:50 AM
i am picking up a used engine and building it up out of the car so there is only like 1 or 2 days of down time.
Re: Engine Swap
Saturday, August 27, 2005 7:52 AM
Well if your doing an intake? Try just a piece of exhaust pipe, and a filter. Thats all you need for about 5 hp.
Also remove the resonator.
Lightened pulleys are good too.
Header, Full exhaust system.
How much money are you willing to spend to get it done right?
Re: Engine Swap
Saturday, August 27, 2005 8:07 AM
brandon condatore wrote:yea well im planning on using the 2.4 for the swap because it has 150 horsies stock..... unless............. hmmm eco eco
swap in the 3800 s/c. what is it like 240hp stock? only problem is that your car will be outta commission for a long time.
SO EVERYTHING!
Re: Engine Swap
Saturday, August 27, 2005 8:14 AM
Only bad thing with the 3800 SC, gas mileage.
Re: Engine Swap
Saturday, August 27, 2005 8:20 AM
its just frustrating. my dads V6 04 mustang is rated at 192 id like to show him up..... he puts me down all the time
Re: Engine Swap
Saturday, August 27, 2005 8:53 AM
it's not just HP you need to look at. torque and weight play a big facter in that. Just because he is pulling 192 doesn't mean that he is neccessarily faster than you. i'm pretty sure the mustang is much much heavy than a J so it wouldn't take much to match him. i may be wrong tho. i don't know much about the mustang.
for my car to reach about 200hp it will be about $2500 to $3500.
i do have the 2.2 ohv so i will have to do a good bit to it.
as someone once said: speed = money.
Re: Engine Swap
Saturday, August 27, 2005 9:19 AM
check your other thread, you can show him up considering you have a stick with what i mentioned there, ive beaten numerous v6 powered cars with the few things i have done. Also try some weight reduction, helps alot, remove anything unecessary. Dont forget, while he may have 192, his car weighs about 3500lbs i beleive, while yous is more like 2500. 100lbs = .1 sec in the 1/4 so you do the math, hes still slow 2
Dreams do come true....
<img src = "http://registry.gmenthusiast.com/images/96sunfireconvt/ModdedFireBlue.jpg">
