ecotec header problems..... - Performance Forum
Saturday, August 27, 2005 2:25 PM
i am having trouble fitting the pacesetter header into place on my ecotec, are there any tricks to getting it into place or a certain way to drop it in? any help will be greatly appreciated. thanks
ecopower
Re: ecotec header problems.....
Saturday, August 27, 2005 5:35 PM
you gotta kinda wiggle it in , but it should for the most part drop in
more so if you have a manual trans
Saturday, August 27, 2005 5:48 PM
does the 4-2-1 header have the same problem and I have a auto trans
Beware the Rouge Dragon.
Sunday, August 28, 2005 9:28 AM
If its 4-2-1 install it in peices. If you need extra room take the rubber trim off the metal peice that flanges out at the top of the hood. Then you can take some vice grips and bend it up temporarily, that gets you enough extra room you can slip it down. I found that its easier if you push down on the header on the drivers side first.
Sunday, August 28, 2005 9:30 AM
just stand on your valve cover, get the header down in there, and jump on it a few times. it'll work its way down in there.
j/k please do NOT do that.
Sunday, August 28, 2005 9:37 AM
thanks guys i got it in there.... i had to remove the o2 sensor and then it fit pretty easily. thanks again for the help though
ecopower
Sunday, August 28, 2005 7:39 PM
yeah. It's a little tight. but it'll go in with a little convincing.
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
