I need Torx Specs For A 2.2 Sunfire - Performance Forum
Sunday, August 28, 2005 10:41 PM
Hi Guys
I need torx specs for a 1997 sunfire for a head bolt set.
Midwest Computer Center Opening Up Soon In Decatur Indiana
Re: I need Torx Specs For A 2.2 Sunfire
Sunday, August 28, 2005 11:30 PM
I did a little search and this is what I found:
www.nyj-bodies.org wrote:
2.2 OHV 95-97 LN2 Fastener Tightening Specifications
Cylinder Head Bolts -- Long | N.m: 63 + 90 degrees | Lb ft: 46 + 90 degrees
Cylinder Head Bolts -- Short | N.m: 58 + 90 degrees | Lb ft: 43 + 90 degrees
Reference Page: http://www.ny-jbodies.org/library/engine/2.2/2.2.asp
Hope that helps you out...
Monday, August 29, 2005 12:02 AM
thanks NJHK
Monday, August 29, 2005 12:14 AM
Xtreme97Sunfire wrote:thanks NJHK
It's no problem...that's why I'm here
Monday, August 29, 2005 1:50 PM
is there any speical torxing i need to do because that what my local gm dealer told me today when i called in here.
Monday, August 29, 2005 2:11 PM
Are you asking about the sequence? If so this should help you out:
Monday, August 29, 2005 2:31 PM
Make sure you use a set of new head bolts. These motors use Torque-to-Yield head bolts. What this means the bolts must streatch a precribed amount to seat properly and used bolts wont streatch the proper amount. You could try using the old bolts, but why risk a blown head gasket and/or warped head.
Tips: Make sure the theaded holes and the bolt head seat are clean, then put some moly based assembly lube(I prefer ARP's on any fasteners) on the threads and underside of the bolt head. This will give more consistant and accurate torque to the bolts. Run the bolts in figer tight and the tighten them a quarter turn at a time, until the proper torque is reached, to seat the head evenly.
Monday, August 29, 2005 2:57 PM
now is it better to change all the gaskets becuase I got the head gasket set?
Monday, August 29, 2005 4:29 PM
^ yes
Monday, August 29, 2005 5:37 PM
not trying to be mean, just don't want someone else doing it to you, it's torque not torxs, torx are the star shaped drivers/screws used to hold in some trim panels, and other things that GM doesn't want the average guy getting into. torque is a measure of force being applied, measured in inch pounds, foot pounds, newton meters etc. and now you know, and knowing is half the battle
somebody please feel free to tweak this , been working in the heat all day.
