tb and intake manifold - Performance Forum
Tuesday, September 06, 2005 6:44 PM
i have a 2001 cavalier 2200 5spd manual...and i was wondering what is up with the intake manifold and tb from http://www.rsmracing.com/catalog.htm ? do i just take out my stock intake manifold and then put the rsm tb on it? or what? is it an easy install, can i do it with the engine in? and what sort of gains would i be looking at, is it even worth it?
ZeRo
2001 Chevy Cavalier
Re: tb and intake manifold
Tuesday, September 06, 2005 7:01 PM
It just replaces the stock one, I changed the gasket in between the head and manifold but I guess its not 100% necessary.
<br><img src="http://memimage.cardomain.net/member_images/8/web/728000-728999/728095_1.jpg">
Yes officer I knew the speed limit was 50
Tuesday, September 06, 2005 7:04 PM
what i mean is buying the aftermarket intake manifold also
what kind of gains would i get with that?
ZeRo
2001 Chevy Cavalier
Tuesday, September 06, 2005 7:05 PM
take out the old replace with the new...not really new, but yea...
easy bolt on, no removal of engine
gain, moving the power band higher....
http://www.j-body.org/forums/search.php?f=2&search=rsm+tb+intake&globalsearch=0&match=1&date=0&threadtype=&fldsubject=1
prob not gonna be worth it on a stock car. your engine hasnt been modified to take in more air so all you are really doing is slowing velocity killing your low end...
might wanna gander at this post http://www.j-body.org/forums/read.php?f=2&i=319033&t=318494#319033
Tuesday, September 06, 2005 8:12 PM
so go with TB and dont go with the IM is what you are getting at?
ZeRo
2001 Chevy Cavalier
Tuesday, September 06, 2005 8:16 PM
unless you are boosted, theres really no need for a 62 or 59 mm tb... and if you dont have a 62mm tb, then theres no point in the intake manifold.
take time on the second link, it explains alot as far as how much air you can actually use in a 2200.
Tuesday, September 06, 2005 8:19 PM
yea...sorry i just got to that now lol, so just stick with stock IM and TB and just stick with aftermarket intake and i will be fine, unless i go for boost. (which wont be in the near future thanks to the $3+ gas prices)
ZeRo
2001 Chevy Cavalier
Tuesday, September 06, 2005 8:25 PM
more or less, if you add a few mods, look into a 2.3 TB which is 56mm.... that should be more than enough
Tuesday, September 06, 2005 8:55 PM
another quick question while your at it lol if i were to buy an ebay intake. (such as http://cgi.ebay.com/ebaymotors/98-99-00-01-Chevy-Cavalier-2-2L-Cold-Air-Intake-System_W0QQitemZ7998073654QQcategoryZ38634QQrdZ1QQcmdZViewItem ) do you know if that will go right to throttle body and i wont need that dumb black box that has "2200" on it?
ZeRo
2001 Chevy Cavalier
Tuesday, September 06, 2005 9:03 PM
with the way those two pipes are shaped, more than likely its a generic picture being used.
so i cant say yes or no on that... will have to email em.
Tuesday, September 06, 2005 9:06 PM
ok i see thanks for your help...know of any intake companies (such as aem and what not) that are like that and pretty much take the route of the stock 2200 intake?
ZeRo
2001 Chevy Cavalier
Tuesday, September 06, 2005 9:15 PM
zero or die wrote:ok i see thanks for your help...know of any intake companies (such as aem and what not) that are like that and pretty much take the route of the stock 2200 intake?
everything basic is listed here
http://www.j-body.org/forums/read.php?f=2&i=215434&t=215434
sites parts etc.
