I just purchased a used RK Sport single cat exhaust. it hasn't come in the mail yet. I havn't done much reading on exhausts and I was wondering if you guys had any recommendations for the installation? What all would be involved and any advice on pain in the ass procedures i could avoid...or would it be better to just send it down to a shop?
Sorry for the noob question
Mine went on in about an hour, you are gunna need new bolts and nuts for the flange at the cat.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
yeah check all the hardware before you install it
they do go on quick
Fire Fighter wrote:Mine went on in about an hour, you are gunna need new bolts and nuts for the flange at the cat.
Install is easy.
I personally have this exhaust on my 2200 and I think that it sounds great. It is not even that loud unless you get over 3 grand.
http://registry.gmenthusiast.com/images/importkilla32/Bullit.JPG
Got mine on in about an hour too I'd say, pretty easy and straight foward install. I used a saw to cut the old piping and stuff off the car and that made it go a bit faster. I have the RKSport header as well, with no resonator and it sounds good other than first thing on a cool or cold morning. Needs a few minutes to warm up.
I've been running it since Aug 02 and no problems other than the hanger on the Magna Flow muffler broke off once and I had to have it welded back on. I took mine to a shop after I did the install to have it spot welded as well, just to make sure it was in place. Cost me $25 to have it done.
You should like it but like others have said, check you hardware first. Good luck with it.
there is a little tab welded on the pipe. i got a hanger off/ from a 4door cav and that helps tuck the exhuast up over the rear axle.
