K i went to a track alst night for the first time n ran about 5 times. i get home and the n i hear a pretty loud ticking noise. i go to bed thinkin nuthin of it because ive had one before but it wasnt as loud n it just went away. it sounds like its coming from the left middle cylinder. is this bad? will it go away eventually like the other one?
also a lil off topic is a 16.591 good or decend in a quarter mile for a 2200 that only has a header and a 2 1/4 exaust?
2.340 - 60,
16.591 @ 80.52 - 1/4
Guesswho69000@hotmail.com
I would say take it to a shop so they can answer that for you.
Also, I would expect 1-2 tenths lower but that's not bad.
I have been having trouble with my header gasket leaking causing that problem, its where the secondaries connect, not on the actual head. Most likely its a gasket, if you want to check yourself turn the car on while its cold and feel around the gasket areas before it becomes to hot. If its leaking you should be able to feel the air coming out. If you cant find the leak take it to the shop. Careful you dont burn yourself on the header.
That is a decent time for a 2200, congrats
15.71 @ 87.9mph 9-17-05
Mr. Resist0r wrote:eh, is there oil in it?
