On 3rd Gen J-bodies, 96+ specifically, you can not chip the OBDII computer. That is garbage. Do not buy it. Enough said...
NJHK is right its junk! Plus look at this, what it basically does it fool the computer into dumping more gas in for NO reason. This in-turn makes your car run worse. Look at the intall of this "speedchip" wouldn't a good reputable company make a product you just dont jam into a contector? Little more fit and finish?
im pretty sure those chips are covered well in the FAQ section...might be worth a peek
"Freedom 'ought to have its limits"-George W. Bush may 31 1999 (who voted for this idiot?)
another way to look at it is this.
If it really provided +20HP, wouldn't it be a lot more expensive.
I've spent roughly $300.00 and I'm probably still about 5hp below that gain.
Header, and exhaust.
There is no science behind that, it's a single resistor that you can get a radioshack for less than a buck.
-Chris
