HELP, Full secret cam swap done now idle problems - Performance Forum
Monday, October 24, 2005 3:31 PM
ok here is the deal. i did the full secret cam swap, both intake and exhaust cams. not at an idle it runs like complete garbage. so i put it on the scanner, and i am getting misfires in all of the cylinders. now when i give it any sort of gas the engine completely smooths out and the rough idle goes away.
so i figured i would adjust the idle air control. and found that there is a screw in there similar to a torx bit, except it has 5 points and a torx has 6. where can i find this tool to adjust it. and is there any other solution to this, maybe any other problems.
suggestions please.........
Sorry...
You have been banned from posting on this site as of 2005-09-21
00:33:32. This ban will expire 2005-09-28 00:33:32 Pacific Time.
Reason: Comments over the top regarding Jordan Kruger and other members in Versus. Also, if you have a problem with a member e-mailing you, do not bring it into the forums.
If you believe this to be in error, please contact us.
Re: HELP, Full secret cam swap done now idle probl
Monday, October 24, 2005 4:06 PM
Sounds like the timing might be off by 1 tooth.
Peter
Gm Stage II W/2.79" Pulley
K&N Drop In Filter
Custom Magnaflow Dual Exhaust
Monday, October 24, 2005 4:08 PM
I meant to say timing chain.
Peter
K&N Drop In Filter
Monday, October 24, 2005 4:32 PM
that's what it sounds like to me too.
Neutiquam erro.
Monday, October 24, 2005 5:06 PM
Yup... timing for sure. I did mine and it fired right back up, sounded like normal.
Monday, October 24, 2005 6:12 PM
Intresting, I reset the timing 3 times, I guess we will be doin it again. this is the first time I have had any issues with the 2.4 timing
2002 Z28: Slp coldair Pac, Corsa Catback, 3200 stall
Monday, October 24, 2005 7:12 PM
whenever your ready rich, i left u a message on your celly before i read this post again. when should i call u tomorrow?
Sorry...
Monday, October 24, 2005 7:47 PM
I have been sleepin, dont feel good at all. BTW not I dont have the tool you asked for. rather odd
Monday, October 24, 2005 8:36 PM
yeah blackz24 told me you were sleepin and that i should call around 10 so that is what i did
i am sorry if i seem to be a bit of a pain in the ass with this
its weird what it's doin...... tell me when u want me to call u tomorrow so that we may arrange what our next step is.....
Sorry...
Wednesday, October 26, 2005 5:22 AM
fats when do u want to arrange something
Sorry...
Wednesday, October 26, 2005 9:53 AM
sounds like the timing chain is off , it happened to dave on his sunfire
i drove it , gave him a suggestion about the timing , and sure enough he was off a tooth
when i did the water pump on my motor sitting on the engine stand , it came out a tooth 1
i was glad i tripple checked it before i put it back in the car
Wednesday, October 26, 2005 10:01 AM
can anybody please explain this secret cam swap too me in full detail i recently bought a 2.4L cavi (99) and am looking around for easy ways to modify it all you need is the 2 cams from the 2.3 L engine ? where can they be found and approximatly how much do they run for, also what kind of performance increase will you see from this mod thanks
Wednesday, October 26, 2005 10:17 AM
Andrew Fletcher wrote:can anybody please explain this secret cam swap too me in full detail i recently bought a 2.4L cavi (99) and am looking around for easy ways to modify it all you need is the 2 cams from the 2.3 L engine ? where can they be found and approximatly how much do they run for, also what kind of performance increase will you see from this mod thanks
Look at the last 2 or 3 pages in this forum you will see plenty of info about this. Not trying to be a smartass by telling you to search but there just way too much info on this in this forum right now for you to use
Wednesday, October 26, 2005 11:04 AM
i got mine on ebay for 125
you are looking for the intake cam from a 2.3 quad 95 jbody(only produced for half the year)
then the exhuast cam from a 90-94 low output quad 4
the combination is suppose to add roughly 13hp to your car
i have a feeling the IAC went bad,,,,, i am going to check it today
Sorry...
